camoyj7
- 18
- 18
- wonder lake IL
I think the 3053 would be fine with a stock Cummins. A friend is doing that swap now. If you plan on 650 hp and 800+ torque I think you will get to see the gear on the outside of the case. Mine performance was lack luster with the 6x6 crew w/12' bed. When it was a 4x4 crew cab is was much better. I was really shocked on how much power was lost adding the third axle. This was with a turned up multi fuel and stock 3053 trans.
