M35A2C build questions
camoyj7
19
wonder lake IL
I think the 3053 would be fine with a stock Cummins. A friend is doing that swap now. If you plan on 650 hp and 800+ torque I think you will get to see the gear on the outside of the case. Mine performance was lack luster with the 6x6 crew w/12' bed. When it was a 4x4 crew cab is was much better. I was really shocked on how much power was lost adding the third axle. This was with a turned up multi fuel and stock 3053 trans.
Str8Jacket
Ocala, FL
That picture looks like he still has the stock hx35 turbo on it.
This is probably a dumb question since the 3053 and the 5 ton are different but would the clutch assembly be the same? I've driven manual trans but I've only ever rebuilt automatics so I'm still learning the details.
camoyj7
19
wonder lake IL
What flywheel is he using?
Here is the secret nobody will share. It took months of research and too many hours on the computer to find the combo. For an Sae#3 flywheel housings I used one from the AT545 Allison #3925223 that has a low driver side starter. A Napa #MBI RC2077136X clutch. And the winning number on the flywheel is #3935205! Or 3908569 or 3935204. found all of these numbers on my new Cummins (not china repop) flywheel. Other flywheel housings are 3903282 high starter mount, 3933387 mid starter mount.
Str8Jacket
Ocala, FL
What about using an NV5600? It bolts right up to a Cummins and can handle more torque. I was hoping Tom would chime in so I could ask about using him to upgrade the 3053. If that's even a viable option for 800ft/lb torque.
Str8Jacket
Ocala, FL
Too long. Unless you plan on moving everything.
I don't have experience under the m35 but should just be moving cross members, shortening the rear drive shaft and having a longer shaft made for the front? While making the CC I could relocate the access for the shifter in the cab.
rustystud
3,374
Woodinville, Washington
You have to be careful shortening the rear driveline. It will not work correctly if you off-road this truck unless you go with double cardan joints (U-joints) . The driveline angle is to great when shortened and the differentials really articulate back there !
rustystud
3,374
Good job !
Str8Jacket
Ocala, FL
Ok thank you. I'm gong to pull measurements for the cummins/nv5600 vs multi-fuel/3053a and see how much of a difference it is.
