- 2,137
- 1,095
- UT
I took a closer look at your photo above, and I can see some streaking on your wheel adapter...that is usually indicative of a failed axle outer gasket, which is an easy fix (remove 8 bolts/lock nuts with 3/4" socket, pull axle shaft out, remove old paper gasket & install new gasket... available from Erik's).
