Hydro-boost / hose o-ring help
barryblakely
Seneca, SC
Had a lead develop from my hydro-boost...what appears to be the "in" hose from the power steering pump. It's leaking around the pipe, not the threads, so it's obviously a bad o-ring. Well, I took the house out, swapped the O-ring that is on the end of the pipe, re-installed, still leaking. Attempted a few more times, tightening a bit more, etc, etc...still no luck. I finally pulled it out one last time and ANOTHER o-ring came out with the first one...as if it was down in the hydro-boost and got stuck on the line this time, as I pulled it out. Can anyone id where the second o-ring goes, down in the hydro-boost sleeve? Does anyone have a link to a diagram of the hydro-boost that would show the O-rings? Thanks!
Retiredwarhorses
4,642
Brentwood, Calif
There is only one O-ring per hose end...install new one but make sure to coat it in ATF before you install it.
this way it won't get torn up when you tighten the fitting.
barryblakely
Seneca, SC
So, the "tube seat" doesn't have an o-ring down inside it? I'm 100% positive I had an o-ring come out WITH the o-ring that was on the hose...maybe the o-ring on the hose split in two, idk, but it sure didn't seem like that...it looks like two separate O-rings...one on the hose end and one that would have come from the seat area.
Sparo2
SoCali
I recommend changing the hose. I had the exact same problem as you and did the same procedures as you. In the end my brother noticed a small hair crack on the fitting. Couldn't really see it. So I just had another hose custom made.
Get a new hose.
Retiredwarhorses
4,642
Brentwood, Calif
As i stated above, there Is an o-ring on each hose end...make sure the old o-ring is not imbedded in the steering gear, hydro boost or PS pump...
GTUnit
155
CA
If anyone needs to find this O Ring in the future here is the info:
NSN: 5331-00-580-6586 Specs Attached
A close substitute is a standard Buna N o-ring with 5/15 ID, 7/16 OD, and 1/16 section width
McMaster Carr pt # 9452K19 or similar.
Mogman
10,604
Papalote, TX
I think Sparo2 might be on to something, maybe the last guy stuck two o rings on it because the hose end was defective.
