M1088 air leak from trailer brake valve in cab
PowerstrokeNC
Greensboro, NC
So my 1088 leaks air out of the trailer brake valve lever in the cab when you depress the brake pedal. At first I thought it was the trailer valve itself, so I sourced another one and put it in.
Well it leaks just the same as before, anybody had this happen to them?
thanks
tennmogger
541
Greenback, TN
You might have a treadle valve (foot brake) leaking when depressed. The rush of air out of the vent up front (center line behind grill) has to source through the trailer or truck brake valve on the dash so sounds like it's leaking in the dash. Been there done that. Had dirt in the treadle valve. Easy to verify: Have someone stand in front of the truck and listen for the vent passing air.
There is a write-up here:
http://www.steelsoldiers.com/showthread.php?140345-Air-Brake-Info-and-Troubleshooting
PowerstrokeNC
Greensboro, NC
I replaced the original with the one I bought from you actually and the result was the same, but I need to double check that I am not getting fooled by the under dash exhaust valve....
Suprman
677
Stratford/Connecticut
I have seen several trucks come thru the auctions with what appear to be newly replaced parts, especially dash valves, that lines are switched by accident. Either by the military or GP trying to put stuff back together for a more saleable truck.
jcarter0909
Red Cliff, CO
thanks
@PowerstrokeNC; Did you ever figure out what the issue was here? I seem to have the same problem with my 1088.
