- 5,637
- 382
- 83
- Spring Branch, TX
I guess this will teach me to try and walk and chew gum at the same time. Only got one right.
See the nurse gave you "the boot"I guess this will teach me to try and walk and chew gum at the same time. Only got one right.
In all likelihood it will. I'll have to see what the followup with the Ortho says but worse case scenarii is I ride with TexAndy and leave the LMTV at home. The trip goes on just uncertain if I'll be able to drive.Mark, will this impact your upcoming trip?
But you got to love the new "walking" casts that are all standard now (allowing bathing, scratching the itches, etc).I guess this will teach me to try and walk and chew gum at the same time. Only got one right.
New McGyver. I'm watching it with my foot propped up.I didn't know McGyver was still on.
Thought you might be watching "ER" with your foot propped up ; )
Still bigger than my calf. I'm hoping it's down enough to get out of this boot by next week. I tried driving left footed today and didn't have much luck.How's the ankle?
I know you want to try, mkcoen; but that doesn't sound like a real good idea!Still bigger than my calf. I'm hoping it's down enough to get out of this boot by next week. I tried driving left footed today and didn't have much luck.
I was changing my timing cover gasket today because of a slight oil leak, and had to remove the fan, and harmonic balancer. The balancer had to come out due to one of the bolts behind the pulley being to long. Glad I did as the 4 bolts you show in the photo above where loose. I was tight, the other three show signs of the threads being hammered from the movement of the fan.I was at speed and it did take out the radiator. Sitting off I10 waiting for a wrecker. Got the rear axle shafts out thanks to some texting advice from NDT.
The culprit.
- Is the Typical Texas breakfast side hashbrowns or grits?Mine had all 6. 4 were still tight and 2 were stripped and just spinning. We're just sitting in Alpine, TX having breakfast on our way back from Big Bend. I'll try and post more when I get home.
