ript
- 0
- 0
- Black Canyon City, AZ
short version - I picked up a '67 m275 that ran when parked (unknown date). last time it was started the motor ran away (4 years ago?) and end of story until I picked it up. I've read all the articles on the IP disconnect rod, HH rebuilds, and decided to see just what it is I am actually dealing with. Last weekend I started it up. Fired right up after a few cranks and proceeded to idle up and begin to run away. I was prepared and choked it out. I'd put a 50/50 ATF/Diesel mix in the filters and wanted to get the ATF circulated in the pump. I have started it and choked it down about 5 times in total now. So, I have a deuce that wants to start no matter the fuel shutoff position and once it starts she runs up up and away until i choke it out - time to tackle the IP.
I pulled the IP side cover and noticed two things - 1: no jesus clip (where did it go, down into the IP? need a new one of those, joy!) and 2: the lever/rod is frozen solid at the 0530 position. I'm going to soak it and clean/mark it up and free it up later. the plunger tip and everything else look okay and move freely.
Is there anything else I should be looking at or concerned with at this point? Put it back together and see what it does?
thanks for any advice/tips! I'm taking tons of pictures and reading the manuals 3 times before doing anything. I'm mechanically inclined just new to the deuce/diesel world and to stupid to be scared of much.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
