Purchased a MEP-803A from GL on 11/28/2016 for $1185 after fees. Picked up in Atlanta Ga on 12/08/2016. First thing I noticed was a big gouge I overlooked in the photos. It didn't hit anything that would hurt the unit's functions and may have been why the bidding didn't go crazy.
Loaded unit in the back of my 2003 F150, extended cab XLT with the 4.6 V8 and tow package. Truck handled fine with the load and cruised effortlessly at 70 MPH. Actually didn't drive much if any different than it does unloaded.
Friday, 12/09 I had a bunch of errands to run and didn't get much done but I did drag the unit out of the truck and onto a trailer. I have an old flatbed I built years ago. I put ramps from the truck tailgate to the trailer and strapped the ramps to the truck bumper. I put a chain to two of the lift eyes on the generator and connected a wench cable from the trailer mounted wench to the chain then drug it off. I had to put tension on the cable then pry under the genset to coax it along and repeat several times before I got it all the way off.
Today, 12/10 I had time to look it over and work on it a little. First I opened the document can and found some paperwork from the reset. Unfortunately they were sealed in a zip lock bag with about 2 cups of water in it. I guess it was from condensation. The zip lock would not open and I had to cut the top off. I peeled all the pages apart and laid them out on paper towels to dry.
The reset didn't seem to be very involved on this unit. It just describes fluid changes and a few gauge replacements followed by a load test. The reset and load test were performed in May of 2010 and showed 2616 hours. There were some accessory documents from July 2010 when it was transferred out I guess. One of those referred to an output test and I guess that was when the other hour and a half was put on it..
I went to Walmart and purchased a couple of group 24 marine start batteries for $61 each. I discovered they are a bit large when I installed them. They fit the battery trays perfect but they just barely make contact with a mount tab protruding off the engine block on both sides. I decided to go ahead and use them and cushioned that area with a piece of cardboard. I don't think it has enough pressure on it to wear a hole in the battery cases but time will tell. Edit: I exchanged these for group 26 batteries that fit in the space without contacting the engine block.
The alternator tension and pivot bolts were loose and the belt was laying loose off the pulleys. The wires were tight on the back of the alternator and did not appear to have been removed. I put the belt back on and tightened the loose bolts.
I didn't see anything else loose or missing so I added a couple gallons of fuel, replaced the oil filter, filled with oil, put distilled water in the radiator, and tried to start it. I used the dead start first to get some oil pumping then used the start switch to warm it up and crank it. The first few times it started it would die as soon as I released it from the start position. On about the 4th try it started and remained running. It tapped a little then quieted down so I guess that was the lifters pumping up. Smoked ever so slightly then exhaust went clear.
https://www.youtube.com/watch?v=9M7QxchAzr8&feature=youtu.be
It wasn't reading any voltage or hertz but the fuel lines were leaking so I didn't run it long. I will have to pull the top off so I can get to the fuel lines and replace those. After that I need to add antifreeze and start working on getting power to read and then on to load testing. I assume this is a wet sleeve engine that requires diesel antifreeze but I admit I haven't researched that either.
The only questions I have right now it why it wasn't reading anything on voltage or hertz? Is it because I didn't have a load on it?
I also found this cap inside that doesn't seem to have a hole to fill. Looks like it might have gone to an auxiliary tank or something. Did I overlook the hole this goes to or does it not belong to this unit?
