erasedhammer
- 58
- 28
- Maryland
So I think I completely understand the removal process except I have gotten stuck on trying to remove the e-brake line. I have taken off the pin holding the small U bracket to the lever, but I can't figure out how to disconnect the cable and the tube it's in from the larger bracket that is mounted on the brake caliper.
Do I just hammer the tube off of the bracket? It looks like the smaller U bracket that the cable mounts to won't fit through where the tube mounts, so I assume I would have to disconnect the actual cable from that bracket as well?
I have read some flashoffroad's instructions on how to do this and some others and none of them tell me how exactly they got the e brake line off.
