1991 BMY M923A2 loses heat when temp gauge hits 200 degrees
WillWagner
2,758
Monrovia, Ca.
Well I guess a digital IR thermometer will be the next tool I buy! As to my temp gauge, it's brand new, just put it in like 4 or 5 weeks ago.
That means nada, they are known to be "erroneous". Verify it with a known good one.
45
West Newton, PA
I hear ya. I'm a technician by trade and I've had bad parts that were brand new. One other thought... could there be air trapped in the system causing these issues> If so, what's the process to bleed out the air?
98G
Former SSG
4,435
If it were a 6.7 or a 5.9 cummins in a pickup truck, your symptoms are spot on for head gasket failure. The very close similarity of the 8.3 make it really suspicious that that is the case here as well....
Csm Davis
393
Hattiesburg, Mississippi
The sender is bad most of the time when the gage is reading to high from my experience. Clean out your cooling system 99% are full of muddy gunk and the tank looks pretty and green.
Sent from my SM-G900V using Tapatalk
WillWagner
2,758
Monrovia, Ca.
Air in the system is purged out by the vent line at the front of the cylinder head and deairiation line from the top of the tanks to the surge tank.
The only similarities between the B series and C series are 6 in line cylinders. Two totally different engines.
Jason O
Lebanon PA
Whats you trans temp running? Temps should run fairly close together, once everything is warmed up due to the heat exchanger in the coolant loop.
Where in western pa are you? I'm in Washington, and keep a truck or 2 at my shop in Carnegie.
Jason 717-673-0845
45
West Newton, PA
Well. tomorrow I'll start off with draining the coolant, and hope that globs of crud come out of there and then try and flush the rad out and see what happens. I have a gut feeling there's blockage somewhere/ Let the truck run for like 30-45 min. today, and after the temp gauge hit around 150, I had heat, and with an IR thermometer, I hit the heater hose in the cab and had around 120 degrees, and the cab was warm & comfy... but a few minutes after the t-stats opened, heat goes away, then the temp rises above 200, so I shut her down. I'm guessing (and hoping!) that once the stats open and the coolant starts to flow (or maybe TRIES to flow) through the system, it's hitting blockage, so we shall see. BTW, checked the oil... totally full and NO coolant in there, and no oil in the coolant, at least none that I could see, so hopefully it will be that way when I drain it.
45
West Newton, PA
IMG_0516.jpgOkay, coolant drained from rad. Nice brownish/greenish color but not nearly as bad as I expected. No evidence of oil in there either, Next, pulled the hose above the t-stat housing... nice, nasty, diarrhea brown crud! Getting ready to pull the housing after my coffee break.
goldneagle
1,007
Slidell, LA
You may want to consider installing a bypass coolant filter. I did it in all my trucks. You can see the install in my 5 ton thread.
45
West Newton, PA
Okay, latest update - pulled the t-stat (p/n 3913028) and it looks pretty cruddy, and the internal bypass t-stat below there, well there wasn't even one in there! Could that be a factor with the loss of heat/temp rising?
Ford Mechanic
Edenton, NC
View attachment 659696 View attachment 659697
There's not supposed to be 2 t-stats in the truck. At least Cummins doesn't list it. I've just had mine apart, make sure you replace all the gaskets in that area after you disturb any of it.
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
Look in the TM 9-2320-272-24-1, pages 3-192 thru-3-195
Like I said a few pages ago. Some trucks are not equipped with them. Some only have 1 thermostat, some have 2. Take your pick and your best guess when going off into these. It is hit or miss on what is what. Some 6 CTA engines will have 1, 2 or even the bypass thermostat. There is no right answer.
wrenchturner6238
29
Beaver Oklahoma
In a post a few pages back talked about flushing the system with cascade and water. I can agree with that and what others have said. I just want to caution you that if you only use straight water during this process and its below freezing it will freeze in your radiator. I am just giving you a reminder about the time of year your are doing this.
WillWagner
2,758
Monrovia, Ca.
Give me your esn and i'll check if it a two stat build. IIRC, some vehicles with an auto trans had just one stat so there is a positive flow through the lower rad hose and trans cooler with the stat closed.
That stat looks wrong and it should have have been in the hole on the left of the pic, the little hole in the bottom of the hsg is the block loop cooling port. When the stat opens, there is a dis on the bottom of the stat that is supposed to cover the block loop route and direct coolant through the radiator. Let me see if I can find a pic
