Bad vibration after hard brake incident.
478
12
Tucson AZ
Hi
I was driving my 1009 today when a nice lady cut me off requiring me to lock em up for a very short moment. After the braking incident I'm getting lots of driveline vibrations. This truck is lifted 4" and the vibrations were not present until this braking incident. Any thoughts or experience?
cucvrus
10,434
Jonestown Pennsylvania
Hunt her down and file a lawsuit against her. Or check and make sure your axle did not shift on the leaf spring centering pin during the hard braking. It's possible. Check closely. Have you re-torqued the axle U-bolts lately? Also check the front and rear drive shaft. Axle wrap can damage things during hard breaking.
WARWAG
CUCVRUS/SNOWCAT NOME are right. Did you re tighten axle U bolts after you drove on them for a while? I checked mine after I returned home from my lift install at my brothers place and they needed a bit of tightening. Not sure what the torque specs are for a M1009 though. I bet your axles moved slightly on you. You could have a "shorter" front drive shaft. Does it still drive in a straight line or is it going one way or another now? Hard to tell from behind a computer screen. Could be a bad U Joint that is giving up the ghost from the extra stress under hard braking. Let us know what you find out. Just be GLAD you don't own a Kristi snowcat............
Tinstar
1,776
Edmond, Oklahoma
If you locked up the brakes and tires slid, I would suspect flat spots.
Doesn't take much to grind off enough to cause some vibrations
This and the other things already mentioned.
478
12
Tucson AZ
Thanks for the replies. Yes I have recently torqued the u bolts but I will check them again. At first glance everything looks fine and the u bolts seem fine too.
478
12
Tucson AZ
I got under the truck today and found the rear ujoint to be bad. It wasn't loose so I missed it before.
I replaced the trouble maker and the truck drives great again. Thanks!
cucvrus
10,434
Thank you for the report back. Many times the crickets drive me crazy when people don't follow -up with the solution to the problem they presented to the group. Good follow-up report.
