- 2,114
- 565
- Davis County, UT
So far, I've covered my M105A2 trailer in its entirety with a 20' x 20' poly tarp for not quite 3 years. I think a full 3 years is about all I'm going to get out of the tarp and bungees before they fail. The tarp and bungees cost me about $85. I wonder if leaving the trailer uncovered and just replacing the regular vinyl soft top wouldn't cost about the same without all the added work of the poly tarp (I surmise the military vinyl top is more durable to sun/weather), though the exterior of the trailer body would be exposed to water collection and rusting. I suppose this would be more justifiable if I used the poor trailer more frequently, say, during the summer months (I don't use the trailer or my M35A2 during winter due to salty roads).
I did add a center support to facilitate better water run off and much less pooling (though this is stressing the stitching on the front of the cover):
With what I do, the whole trailer body and front hoses/electrical are (mostly) protected from weather an sun, and I don't have to reassemble the trailer (sides, bows, and top) when I want to use it. But I do have to uncover it and recover it when I'm done, and get out a ladder and shovel the snow from the top of it when I'm clearing the driveway. I'm not mentioning the tire covers, as well, there's not a better option for that other than fully indoors and resting the trailer on jack stands.
As can be seen, I have a lot internal conflict as to "the best" way to store my trailer - and I fully realize that is a use-dependent answer.
For trailers with soft tops, M105, M101, M103, etc.; what do you do when storing your trailer? Why?
- Do you leave it as is and just replace soft top, air hoses, and electrical plug when it becomes too weathered?
- Do you cover it with a tarp or other shelter?
- Do you remove the soft top, bows, and/or side racks and tilt the trailer to ensure proper water drainage?
- Something else ingenious?
