Allison 3500sp trans wiring
Socommfg
9
n. Augusta sc
I am looking to put a 3500sp trans and 3116 cat in my Ford f350 dually. Can anybody give me the info need to wire the trans and controller in? I have a parts truck (S&S) doner, but no cab wiring or parts.
Is this a worth while project or should I use a Manual shift set up.
My icon is the motor setting in the Ford Chassis..
Ernie
scottmandu
36
Texas
Ernie
You need to find out if the trans is WTEC II, III or IV and use he appropriate controller.
snowtrac nome
140
western alaska
if you have a doner truck you should have the controller. There is a adaptor harness to go from a wtec 2 to 3 trans if some where along the line the trans was changed I believe Allison can sell you a stand alone harness to connect the controller to the transmission might be easier than building your own harness
Suprman
705
Stratford/Connecticut
I have the trans to cab harness for either control. It comes down out of the drivers side cab hump along the drivers side frame rail, a branch off goes to the throttle position sensor and then over the trans to the passenger side where it meets the pigtail that comes off the trans. In the cab alot of the trans wiring is integrated into the main dash harness though.
