M1009 Tie rod bar conversion using dana 60 parts
doghead
4 Star General /Moderator
1,193
The correct terminology can be sourced in the parts TM, as well as the correct GM part number.
Chaski
56
Burney/CA
That would be a tie rod. The tie rod ties the left to the right wheel. The drag link ties the pitman to the steering arm.
Moog part numbers below, can be had from Rock Auto for a very reasonable price.
MOOGDS905
MOOG ES2011R
MOOG ES2012S
EDIT! ABOVE PART NUMBERS ARE FOR A DANA 60... Not a 10 bolt, not correct for a M1009 with stock axles.
13
Tucson AZ
MOOGDS905
MOOG ES2011R
MOOG ES2012S
excellent thank you. Do you know if these are quality parts I can rely on?
Chaski
56
Burney/CA
DOH!
Those part numbers are for a Dana 60. Null and void for your ride. As far as the Moog stuff goes, it seems to work well for me.
Clearly the sensible thing to do is to use the bent tie rod as an excuse to do your axle swap.
13
Tucson AZ
DOH!
yeah I know but the axels I had my hands on are looking like they won't be a cost effective acquisition. So who knows how long it'll take me to find the next set!
Chaski
56
Burney/CA
At least the good news is that your local self service wrecking yard should have a tie rod for you since there is about a zillion gm 10 bolt front axles out there.
478
13
Tucson AZ
Still hoping someone can chime in with an aftermarket option for me. The local salvage guys are pretty bad around here. The GM part number returns nothing 14026804.
Kaiser67M715
26
NH
Off road design, they have several options for hd steering linkage, might be the thing to invest in if you do more off-roading.
