- 6,847
- 663
- Stratford/Connecticut
One on the right has the check valve
Does the one on the right have one or two check valves? Asking cause one on the right has a thingamabobber sticking out at both the end of the "Tee" and the end of the "L". and am curious if these are the check valves your speaking of.One on the right has the check valve
Do you recall the corresponding Barksdale part number? (it appears the PowerPackers are no longer available)I'm still working on one. Figured out the leveling valve is actually made by Barksdale. Costs a lot less than the Powerpacker branded version. I have one truck no matter what I do or swap the airbags inflate to the max and the darn level valve leaks. It's not the level valve swapped that twice. Replaced the clippers check valve behind the manifold control. Verified lines on other trucks. Tried the system with less air pressure.
Cab Air ride leveling valve "Selector Valve Rotary" | Applied Power 13041 | PP975900 | Power Packer | PP975900 |
