bigsix
- 0
- 0
- huntingdon ,tn
is it possible the govenor could be causing the air loss?
He said he is maintaining 110 psi. It sounds like a low air problem but if he has 110...how could low air be the issue? Tranny linkage comes to my mind.is it possible the govenor could be causing the air loss?
Tap on the block with the roller on it that is where your parking brake is. And work the roller a few times up and down. With your truck running and parking brake off. If you don't hear the honk out of the stack when you pull the roller up then its stuck.hello again folks, well i have been driving in reverse for an hour getting home.my m931 was getting a test run and i stopped to turn off. when i put my foot on the pedal it wouldnt move like the park brake was on. it will only rev slightly in all forward gears. it doesnt have neutral but it will go in reverse in R and neutral. So.........i backed in a circle in the middle of the road and backed home. air pressure is a little low . about 110 on both gauges. no wipers or horn . like there is no air pressure. i can hear air purging like through a baffle but it got too dark to see. does anybody have any ideas?
What air pressure are you running? Same as 14's?395s ride great. More power pulling on hills. Also the front tandem is no where near as bouncy as with 14.00s. Pretty smooth actually. View attachment 671245
Sent from my SM-G860P using Tapatalk
That little part is where my other tube was cut off. Vs the stock pickup tube. That is quite a few gallons to pickup over the depth and span of the tanksimp I love how you explain your mods. I defiantly save them and have your emails. Cant wait to start doing those you sent me. Thanks!
