tobyS
840
IN
is it possible the govenor could be causing the air loss?
He said he is maintaining 110 psi. It sounds like a low air problem but if he has 110...how could low air be the issue? Tranny linkage comes to my mind.
simp5782
Feo, Fuerte y Formal
9,492
Mason, TN
hello again folks, well i have been driving in reverse for an hour getting home. :oops: my m931 was getting a test run and i stopped to turn off. when i put my foot on the pedal it wouldnt move like the park brake was on. it will only rev slightly in all forward gears. it doesnt have neutral but it will go in reverse in R and neutral. So.........i backed in a circle in the middle of the road and backed home. air pressure is a little low . about 110 on both gauges. no wipers or horn . like there is no air pressure. i can hear air purging like through a baffle but it got too dark to see. does anybody have any ideas?
Tap on the block with the roller on it that is where your parking brake is. And work the roller a few times up and down. With your truck running and parking brake off. If you don't hear the honk out of the stack when you pull the roller up then its stuck.
Mine sticks periodically. Once monday morning and about 6hrs ago.
Sent from my SM-G860P using Tapatalk
simp5782
9,492
Mason, TN
395s ride great. More power pulling on hills. Also the front tandem is no where near as bouncy as with 14.00s. Pretty smooth actually. 20170315_104333.jpg
simp5782
9,492
Mason, TN
2100 is 57. 2225 or so is 60. I go off of engine noise as to where i set my speed. Sometimes at night at 1900 to 2000 she purs so i just run at that. Before 2100 was 60. 20170316_075543.jpg20170316_075607.jpg
simp5782
9,492
Mason, TN
simp I love how you explain your mods. I defiantly save them and have your emails. Cant wait to start doing those you sent me. Thanks!
That little part is where my other tube was cut off. Vs the stock pickup tube. That is quite a few gallons to pickup over the depth and span of the tank20170317_133219.jpeg20170317_133638.jpg
twisted60
250
Jupiter, Florida
Applied truck bed liner, installed 2 LED light in front grill, moved/re-mounted rear LED back up lights, swapped out air pressure gauges in the dash, all in all a good day.
IMG_3265.jpg Truck bed liner (Rust-Oleum bed liner paint)
IMG_3263.jpgIMG_3270.jpg 2 x 12' LED's
IMG_3271.jpg Back up lights on.
Taking tomorrow off.
srodocker
70
Lacey, Washington
Going to get my rear top prepped to send to awning place to get the rear flap sewn back on. Buy some things off amazon for future projects. And create more projects in my head all while theres a large actual project list to do on it ha!
Also used the harbor freight bed crane to pick up a newly acquired generator from a fellow SS member. Will be posting about that one as never seen this type of generator and need to get a manual for it.
