- 629
- 22
- 18
- Port orchard, WA
They are all Detroit Soft Lockers.Nice. I was just reading that locker group buy thread. How is the locker activated? Is it a Detroit style where its locked when power is applied?
He got it from Bryce. He is a member here and the source. His info is on a locker thread somewhere. Use search and you will eventually find it. I don't have info off hand.where did you score the locker was it directly from meritor or someplace else
its always on on until one wheel speeds up in a corner and it releases. Wish it was an arb but.. beggars can't be choosers. Only installing one in the rear. I'll post more photos of the gear lash set up. Ran out of time tonight.Nice. I was just reading that locker group buy thread. How is the locker activated? Is it a Detroit style where its locked when power is applied?
This may be an obvious questions,but.......I assume you have a second 3.07 chunk as well for the front?Got it from Bryce he had them made, eaton/Detroit no spin lockers, I don't have his contact info handy I can send you it later. The best part is that it's 3.07 ratio gears its installed in.
of course I have the second chunk, lol. I actually had the gears before I had the truck. I'm setting the lash myself, using a meritor guide. Looking a the lite wear on the ring the pinion depth is good, now just to left right and preloadThis may be an obvious questions,but.......I assume you have a second 3.07 chunk as well for the front?
Who is setting up your backlash?
I just had to ask..... could not resist.of course I have the second chunk, lol. I actually had the gears before I had the truck. I'm setting the lash myself, using a meritor guide. Looking a the lite wear on the ring the pinion depth is good, now just to left right and preload
