Isawfrizzy
- 0
- 0
- St. Paul, mn
Thanks, the leak is around the handle of the valve so I'm guessing the stem seal dried out.I think you just have to replace them. I have seen a lot of them that leak. Just try to keep good seals on the glad hand and that will help.
Yea just swap it out. Home depot or lowes. 1/2 "pipe. I replace both rears together and then the fronts together since the other is just as old
Sent from my SM-G935P using Tapatalk
Everyones got jokesYou using the Rainbird sprinkler valves to match your intake?
Thanks for all the input. I'll probably just buy 4 new valves so I know where I stand with those.
This needs emphasis. LEAVE THE FRONT RIGHT ONE ALONE!FYI, I would not replace the one on the front service if you have one there. If it gets closed your brakes will slowly lock up.
Don't ask how I know that.
Ok, you got me. what's the front right one do? Is there a pneumatic schematic on how these glad hands work. I looked at a couple TM's and the ones I saw just showed the components not how they interact.This needs emphasis. LEAVE THE FRONT RIGHT ONE ALONE!
The OP's comment of "I'll replace all 4" leads me to think he's unaware....
The service front has to vent when you release the brakes, that is why it has a little vent on it like the ones on the axles.
Thanks for the heads up. This is my first 5 ton. Steep learning curve.
