- 4,419
- 3,677
- Fort Worth, Texas
Honestly no idea since the supply on 5 ton trucks has dried up.Bad ass. Love that thing. What price are you hoping to get out of it?
That is a fine looking hard top. One of my AC installs there was a pin that was pushed in and the fans would not come on.Installed hard top!
View attachment 682169View attachment 682168
Rearranged all electrical stuff and mounted bus bars, 12v fuse block, 24v > 12v converter (silver finned thing top right), back up camera box, to back wall.
View attachment 682171View attachment 682170
Then, I finished troubleshooting an AC problem. Compressor Wire had no juice. After fooling around with wires and connections, it has juice. Same thing I have done a dozen times. I guess a pin wasn't connecting of something. Now my badly rigged compressor juice circuit has been replaced with the proper wiring.
ThanksThat's a fine looking group of ladies (and one fine young man, also) with some fine trucks.![]()
Nice. I habe been thinking about getting one for my son to drive to high school. He is 3 now. I figure get one cheap and fix it up over the years for him. Then he can drive it when he gets in high school.View attachment 682195
Made a deal for this one
Sent from my Webslinger using Tapatalk
Con not be put on roof as far as I know. There is a model that can be roof mounted. Red Dot makes them. Can't recall model number.Can that A/C be mounted anywhere...such as on the roof? I still have the bench seat in mine so I'm limited in where I can put it.
Yeah it looks better in color.Okay. Now I get it.
The logo wasn't making much sense to me before. But now that I see the NAME of your company, it all comes together.
Thanks, I'll take a look around for it. Not a big fan of it being on the rear wall because of potential access to the RV part when it is built.Con not be put on roof as far as I know. There is a model that can be roof mounted. Red Dot makes them. Can't recall model number.
You can mount it higher up. Someone here put this AC in their truck with the bench seat still in it.
We still get rain out in the desert, it just isn't as much as the rest of the country, or as much as I'd like sometimes lol. I wouldn't drill the through the roof to install it though if that's why you said that. I'd make a frame for it to hang from overhead and still keep it as tucked up as possible. Of course, I may not even bother with it and just have an A/C unit in the RV part that can blow it into the cab as well.The red dot kit for the m915 a1 series of trucks is roof mounted. Wont do well on a 5 ton roof but i guess water leaks dont matter in the desert
Naw Don you just like them, like some guys like redheads. When you get to ten or more it's a fetish, 20+ and it's an addiction. I am working on a 12 step program, I am down to less than 20 at my house and have closed the lot at the base so I can't easily just buy more, hope to be under 10 by the end of the year.Well, I may or may not have a 5ton fetish!
Don G
