Bravojmc
- 5
- 0
- Palisade, Colorado
Looks great!Mine has the same setup with the vertical forward bracket repositioned on the lower rail and welded in place.
Mark
Mark
I was on the road all day and didn't have chance to get back to the seats today. I too will slant the front and have the seats function as normal. I have it worked out in my head just have to get to it. Overall it looks to be fairly easy-ha ha I will post pics. when done. Should come out niceVery interested to see how you finish this. I have a set of troop seats standing by to be cut down to fit the available space behind the 4-man soft top. Just haven't sorted out exactly how to do it. Would like to retain functioning troop seats, not just the side rails.
I pulled the voltage regulator off today. Everything was heavily covered with carbon from the brushes but the alternator brushes were at least at 50% so I wasn't worried about needing to replace one. I sprayed all of the internals in the regulator cavity with Lectramotive. Once everything was dried out and cleaned up I noticed the voltage regulator adjustment resistor seemed a little boogered up. Decided to put it all back together and see how it functioned, hoping it just needed a cleaning, but it's the same. I can have 30 V or 25 V but nothing in between. I am going to order a new regulator and then later put the old one on the bench and see if it is repairable with patience. I was an electronics technician in a past life in the Navy, so maybe I can repair it. But I'm not going to let my HMMWV languish while I try!It may be a little while before I can report on that, since my almost immediate failure in the engine bay occurred on the LEFT side... I suppose it will be in the way for some stuff, yes, but it's not that hard to remove the three bolts, so if it's more than a half hour job one could pull it off and throw it back on after. I'm glad to have the jack out of the rear passenger footwell. I don't have any accessory boxes or auxiliary storage fab'd up yet.BDGR
What kit did you use for the forward facing lights and covers?Also installed gps antenna and some warning lights![]()
Sent from my SM-G935V using Tapatalk
How is it kept in place? Straps?Another little touch to the humvee, I took my old tool box from my MKT 90 and gave it a paint job and turned it into the humvee tool box for quick fixes.
View attachment 682834View attachment 682835View attachment 682836
Keeping it in place? Well that is still up for debate. Thinking about just setting it somewhere inside (if it will fit?) or i will have to strap it down on the deck part.How is it kept in place? Straps?
Oh how i wish that was true Mario. But, just going to put basic tools inside just in case the Humvee springs a leak or something. But I did buy the 24 volt impact for the M998 which plugs in to the slave port under the passenger seat. The Impact really comes in handy when taking of the Humvee Wheels.What's inside of it? Humvees never break, so is the Box empty?![]()
The humvee. It plugs into the slave port. And works great.What's your source for the 24v impact?
Thanks. That looks like exactly what I had in mind. I'll probably just blatantly copy what you did.View attachment 682971View attachment 682972View attachment 682973View attachment 682974 Just have to weld 1 pull pin bracket on each side and trim down inner seats.
