- 1,450
- 123
- 63
- Gray, GA
I've been working on servicing all the hubs and decided to start with the right front since the inner axle seal was leaking. It wasn't much but after a couple hundred miles I'd have about an ounce of GO in the bottom of the knuckle.
Tear down of the tire, brakes and hub went smoothly. Removal of the washer and seal (NSN 5330-00-145-8355) from the retainer also went smoothly. I left the retainer in place undisturbed since I was only replacing the seal. I found the spindle bushing was heavily worn so I figured the excess movement of the shaft was the cause of the leaking seal, along with the fact that the rubber was not really pliable anymore. I replaced the bushing, installed the new seal in the retainer with a seal driver and installed the washer back in the retainer. Everything looked good so I reassembled everything, to include bearing repack and brake part lube, and took it for a 20 mile drive.
I got back and removed one of the bottom king pin plate bolts and got about a cup of GO out of the knuckle. We'll that's not good...that's worse than before, and with a new seal. So back to the TMs and forum searches to figure out what happened. That didn't help so I tore it back down thinking I missed something.
I test fit the seal to the axle shaft to verify it was correct. I checked the seal surface on the axle to insure it wasn't scarred. I installed a second new seal with silicone around the outer ring to insure it wasn't leaking through on the press fit side. I reassembled everything and went for the same drive. Same thing when I pulled the bolt...cup of oil.
I have the axle vented under the hood with a line and filter so there's no pressure. The GO level is 1/2" below the fill hole so it's not overfilled.
So now I'm at a loss as everything seems to be properly installed. This has become a little aggrevating for something so simple, given the amount of work involved to get to it. I do know my way around axles and seals so this isn't something new to me. So a few questions...
Am I missing something simple?
Does the retainer need to be removed to replace the seal? If so, why? The seals went in fine without the retainer removed. I have a bunch of these seals so I don't forsee buying a seal/retainer assembly.
In the pictures below, which side of the seal should be facing out when installed? The first picture shows the way I have it installed. The second picture is facing the inside of the housing. The only side giving access to the tension spring and seam for the outer metal ring are in the second picture if that helps. I installed it the same as the original but that doesn't mean the original was installed backwards. The work package I've been referencing in the TMs only shows retainer assembly replacement, but not independent seal replacement.
Any help would be much appreciated.
