123mack
- 11
- 18
- Jemison, AL
Any one know of a substitute or replacement hard drive for the MSD V2 diagnostic computer? I have one that's good just a fried hard drive.
It's going to be a standard laptop hard drive that's in a specialized tray... Either IDE or SATA. Take a picture of the connectors on the drive and the label on the drive and I can give you an immediate answer!Any one know of a substitute or replacement hard drive for the MSD V2 diagnostic computer? I have one that's good just a fried hard drive.
Hey, since you have one...how hard is it to setup a bracket to space the hard drive correctly into that bay? My worry with buying one of these old laptops is getting the hard drive set in just the right position. My next concern is spare batteries...any chance you know of a commercial equivalent battery?They're just small IDE drives in the ones that I have. Do yourself a favor and instead of buying another HDD buy a solid state replacement that will hold up better to rough handling. You can get solid state replacements already configured for IDE applications that will plug right in.
Intended purpose. Diagnostics. My Dell that I keep bumming off a friend works just fine to do the job, but it'd be real nice to be able to power the laptop off of the vehicle through the MSD-ICE serial cable assembly. Plus, it'd be kinda cool to see how the auto-installer actually runs for the software.You need the original caddy and Miltope wont help you. What are you trying to use the laptop for?
I unfortunately would need the Windows environment up and running. I'm trying to use mine for diagnostics using the Miltope suite of software. I know there's Windows 2 Go for Windows 8 - Windows 10, but I'm not sure how nicely that would play with this. Would also inevitably be egregiously slow.I tried what this guy did, a thumb drive with puppy linux. www.youtube.com/watch?v=oFtd71cH8No Works so far.
Already ahead of you. Disc 2 does have very basic tests on it that you can run on your own if you want raw data. I have the HMMWV IETM and I know a few others are out there. The HMMWV IETM seems to automatically capture values as you go through troubleshooting and will build up a collection of what has failed/passed during the testing you've done to give you a list of possible errors in its fault wizard. As well, I have a 4L80E TCM on board, so that means the GM UART connector with the DPA will yield actual data and the new S3 also has a diagnostic port that can function with the DPA. Plus in my real-world use, I've seen that it runs fine on Windows 7. I haven't tested every single program on the disc, but the core ICE drivers and utilities all seem to run A-OK on Windows 7 32-bit. There was a lot of protest when I attempted to install on a Windows 10 64-bit machine, but mostly it was kick-back because of the 64-bit aspect.Made to work in xp. You really need the interactive manual to run the flow chart diagnosing specific diagnostic tests. The miltope discs that come with the msd are only operating system and diagnostic interaction software. The big round ice diag port dosnt support much. If you have a standard diag port like A1 Lmtv then you can use a civilian code reader it's a lot faster and easier.
Really? I've been using EMS2 and it works A-OK on Windows 7 Pro 32-bit AND Windows 10 Anniversary Edition 64-bit for me. I can "do everything" on the 7 32-bit config as that's my test rig. I can open the program and go through the flow charts and such on Windows 10 64-bit, but I haven't even attempted to try using the ICE kit with it due to all of the error flags I was given while trying to install some of the ancillary programs. I can shoot you a copy of my install files so you can see if maybe you have a bum copy. I can't remember where I sourced these from...might have been LOGSA or another .mil site with public distribution.My biggest problem is the ietms won't load in win7 for me. I have the older reader program. There is a newer version ems ng reader but I have not been able to get my hands on it.
PM me if you decide you need a copy of it. It's version 2.8.1.4.I can load the manuals. The ems software gives me an unsupported operating system error in anything after xp. Maybe you have a newer version. When I did first load my system I put the first miltope disc in and it was all automated. Asked for the second disc when the first one done. I haven't had time to try and run diagnostics on my Lmtv. I have the serial interface and a newer USB one.
Thank you for sharing the rig you have for that drive. Pretty clever to use to the cable so that you don't have to have the alignment perfect. I've got you covered for the recovery discs. Once I get home, I'll figure out file sizes of the discs so that we get the ideal transport medium setup for you.I've been trying to get one of these going for some time now without much luck. I've tried loading an OS onto the HDD and then installing in in the computer, NG. I've tried using the internal CD to load an OS and it seems to load fine but then doesn't see the pointer after the system boots up so I think it must be a driver issue. Would it be possible to get a copy of the software from someone?
I've posted a picture of my HDD solution using a drive carrier tray made from a piece of aluminum and a cable I found on Ebay. This solution solved that problem but I think I still need the original Miltope drivers.
Thanks in advance for your help,
KurtView attachment 688607
My Miltpe V2 Hard drive just went south. Does anyone have a copy of the CDs needed to reload the Dignostic software for the MSD? I can reformat the drive, just need the software and IETMs for HMMWV and M35A3.Already ahead of you. Disc 2 does have very basic tests on it that you can run on your own if you want raw data. I have the HMMWV IETM and I know a few others are out there. The HMMWV IETM seems to automatically capture values as you go through troubleshooting and will build up a collection of what has failed/passed during the testing you've done to give you a list of possible errors in its fault wizard. As well, I have a 4L80E TCM on board, so that means the GM UART connector with the DPA will yield actual data and the new S3 also has a diagnostic port that can function with the DPA. Plus in my real-world use, I've seen that it runs fine on Windows 7. I haven't tested every single program on the disc, but the core ICE drivers and utilities all seem to run A-OK on Windows 7 32-bit. There was a lot of protest when I attempted to install on a Windows 10 64-bit machine, but mostly it was kick-back because of the 64-bit aspect.
Are you still needing assistance with the MSD diagnostic software?My Miltpe V2 Hard drive just went south. Does anyone have a copy of the CDs needed to reload the Dignostic software for the MSD? I can reformat the drive, just need the software and IETMs for HMMWV and M35A3.
Thanks.
