erasedhammer
- 61
- 28
- Maryland
How did you install a light in the tachometer? I've been looking for a bulb and socket the right size but I can't find anything, at least for 24v.
Ah yes I see that now. Only I have the tach harness that came with my kit and it does not include wires for the internal light, do I make my own harness or is there a harness that includes lights.These tachs come with internal lighting and when hooked up to the vehicles instrument light circuit will dim with the gauges.
I agree, nice & clean and good spot. Don't have to take your vision to far off center.What did you use to make the hole? Keyhole drill? I think that's the best looking spot for it Ive seen.
I had to replace the transducer (sender). When I pulled it, the "bump" on the shaft which engaged with the drive off the engine was corroded to where it wasn't even turning. Works great now.Looks great - I've been waffling on where to put mine. However, I can't get mine to work. Wiring is done properly, but no signal. The 2 wires from the yellow transducer feed the signal - does the order matter? I remember reading that either wire can be connected to either of the signal connections on the tach. Otherwise, perhaps a bad transducer? I'm stumped on this one.
Thx,
Jon
I'd gladly take one off your hands. What's your price?I have a pile of those yellow transducers.
Also some original tach systems.
Better post up a photo of connections on the back of the tach and let us know the year and model of the vehicle. Maybe we can help more that way. Does it look like this???thatsounds easy enough but I only have one trigger wire on this tach plus keyed hot and ground and light so still stumped??
mogger7
