erasedhammer
- 58
- 28
- Maryland
Believe me I've heard all the gripe about these things. But I love the look of them, I don't mind the functionality, but I would like to do everything in my power to prevent the unit from catching fire. And I got this unit used for $50.
I plan on running ground wires to the gauge cluster, body, and negative shunt in the battery compartment. I heard that the most common cause of fires is power surges, what I put circuit breakers on the lines coming in from the lights?
I heard units after 2005 had the issue corrected. I don't know what serial number those were. But for some reason there are two labels with s/n info. one on the inside and one on the outside.
The pic for the inside label isn't readable, but the s/n is 33503 00912 and the model is MKE CDA. I don't know what the other number is though: 9341-15637-008/B its a bit odd for a NSN.
![IMG_20170803_170641.jpg IMG_20170803_170641.jpg](https://www.steelsoldiers.com/data/attachments/475/475087-c31cda72d13afbb4036739c9e9fe7a98.jpg)
![IMG_20170803_170615.jpg IMG_20170803_170615.jpg](https://www.steelsoldiers.com/data/attachments/475/475088-ef76a436cf678b7d20b07a28080f91ea.jpg)
![IMG_20170803_164250.jpg IMG_20170803_164250.jpg](https://www.steelsoldiers.com/data/attachments/475/475089-0476a6c2528f0d81c2dedff381fbc5d2.jpg)
![IMG_20170803_164148.jpg IMG_20170803_164148.jpg](https://www.steelsoldiers.com/data/attachments/475/475090-f8004bfae850f28654d0aeb607875fc0.jpg)
![IMG_20170803_164142.jpg IMG_20170803_164142.jpg](https://www.steelsoldiers.com/data/attachments/475/475091-c9807a5bc74e7a49e183af2141c7e304.jpg)
I do not plan on installing the unit until I am pretty sure that it is safe and won't catch fire. Also how vibration resistant are these things? I frequently go on some extremely rough roads.
