M-series flasher relay - civvy conversion how-to
firewarrior
Midland,Tx
I know this post is 2 yrs old, but I want to say thanks for doing this...I just upgraded mine using your instructions and everything looks and works perfectly!!
1,161
Thanks. I am still running on the original EG22 relay I installed at the time of doing this. I have inspected it a couple times and one time, there was some condensation in the plastic housing. I removed the cap that I had installed and put a downward facing pipe on it so it could breath. Haven't checked it since I did that. Having it open means if I ford water up to the box, the box will fill up with water, so this is a temporary solution I don't care for. Still deciding what to do.
fcreamer88
Abilene Texas
OK, I set out to do this repair and low and behold, my flasher is different. My cannon connector is molded into the box. I was able to remove most of the sealant puddy around the connector but all i was left with was 3 pins that came out the back of the connector. Any idea of a part # for just the cannon connector? I have my napa guy searching but haven't heard anything just yet.
jasonjc
291
Gravette Ar.
I have the same plug I just soldered the wire to the pins.
Also used the EG23 flasher with 3 pins. I thought one was a ground but its not. X is power in and L is load out to the light. Don't know what the "P" is for. I also put a fuse in the box.
Thanks for the idea Clinto!
just me
13
phoenix,az
The "P", I think, is for a separate Pilot indicator lamp. Me being lazy, and having not seen thus post, I just used a clip to mount the flasher to the glovebox side where the original failure box was. I removed the cannon connector and soldered connectors to the wires. Reversible, but requires soldering. I don't Ford, so wet isn't an issue.
fcreamer88
Abilene Texas
This problem has plagued me! I did the conversion, popped the headlight and no flash, replaced the flasher and now all I have is constant power to the lamp. Luckily I found a neighboring fire department who is decommissioning a deuce and was willing to part out the flasher module. Now to rewire in the barrel connector and cross my fingers. Still at a loss on this, Clinto....any ideas?
cattlerepairman
3,513
NORTH (Canada)
I have received the parts, built and installed the unit and can report that the box I mention above mounts perfectly to the original bolt holes (using the original bolts, after drilling out the mounting tab holes a little).
This is one of the best safety and peace of mind modifications to the truck that one can do! I love the stock look of the setup.
duttoer1959
Lafayette, Indiana
Just want to say thanks for this information . Have had my truck (Jeffery) since 2003 . I don't know how many of those junk flashers I've been through . I used the Grote 44860 with the aluminium box , turn signal plug from ebay and connector from the old unit . It works perfect . Also inside the box is an extra flasher just in case . Thank you guy's . Great info and money saver .
Tinstar
2,547
East of Edmond, Oklahoma
Argh. Went to put my new relay on and nothing! And my drivers side headlamp popped. Any ideas? Clinto, Can you message me?
Did problem get solved?
What was issue if so?
All issues and fixes should be posted here so it will help others.
Noticed Clinto didn’t post anything after your question.
1,161
He had PM'd me and we spoke offline.
He told what the conclusion was but I can't remember now. I think he ended up using a stock flasher relay.
EDIT: went back and looked at my PM's. He said he couldn't get it to work and ended up buying a current replacement m-series relay.
Not sure what was up with his truck, I've done this swap on dozens of friends trucks without issue. Mine has been in the truck now since January 2015 without issue.
nchittendon
La Crosse, Wisconsin
I recently had my original taillight short out, and melt part of the housing. The gasket between the 2 halves was in bad shape, and let water in. It filled with water and corroded enough to short. In my hobbiest mind, I decide to upgrade instead of just replace. So I look into the military LED lights. Too rich for my blood.
I decide to do a civilian LED conversion, to my OWN tastes. Had some custom brackets made, had everything powder coated, and snagged the lights themselves for $7 a pop. I like that better than the $200 a pair I've seen for the military LED ones.
This was my photoshop vision:
And this is the finished product:
But now, they blink funny. So, here I am. Looking to build a civilian upgraded flasher box. Was it ever determined if the EG22 plays well with LED's? I'm so close and getting anxious to drive my truck again with her new "bling."
1,161
So, I have to post an update.
After 3 years on the truck, one of the plastic mounting tabs on the box broke. Now, this may be my fault, as I tend to pull the box off and use it to test customer vehicles before I build another relay. So maybe that had something to do with it............
But, after thinking about it, I think the heat and vibration of the engine compartment are probably hard on that box. So I ordered one of the metal boxes The Stig used to build his and I've now upgraded my flasher to Version 2.0.
20180301_172335.jpg20180301_172341.jpg20180301_172404.jpg20180301_173422.jpg20180301_173424.jpg20180301_173432.jpg20180301_173437.jpg20180301_173441.jpg
