HMMWV cleaning windshield??
191
auburn,indiana
I have green over spray on the windshield,what can I use on it to get it off safely? I tried window cleaner and a razor blade but it seams the windshield is maybe bullet proof? It's soft?
Sent from my XT1585 using Tapatalk
Scar59
41
Mt. Eden, KY
A new single edge razor normally does the trick. Not sure about "soft" glass. Mirror Glaze makes a clay bar for overspray/detail work. Works great on auto finishes and glass.
Sintorion
13
Fla
Be very careful if using a razor blade because you are right about it being soft. Mine was very scratched and I took it to one of those mobile car detailers who polished out the scratches.
papakb
1,183
San Jose, Ca
You didn't mention which variant of HMMWV you have but if it has ballistic windshields and the soft anti-spalling polymer is on the outside they're installed backwards. The anti-spalling plastic should be in the inside top prevent glass particles from spraying the crew compartment if hit by a bullet. NEVER USE BRAKE CLEANER ON THEM!! Most brake cleaners have some severe solvents in them and warn right on the labels about using them anywhere near plastics.
If you just have standard safety glass then it shouldn't be soft and a straight edge razor blade should take off the overspray pretty easily. You can always use a paint thinner like xylene or acetone if it's just glass.
gunsgreg
Fort Smith, Arkansas
Take notice that some on that website that sounds like flea gay where selling those HMMWV 3/4" ballistic windshields as interchangeable for both sides. Beware that they are not and are side specific. As has been explained above...
erasedhammer
58
Maryland
I had some overspray on my windows (from me). Put some wd40 on a rag, paint came right off. Cleaned the wd40 off and used glass cleaner to make sure none was left. Windows look brand new now!
snowtrac nome
137
western alaska
as I remember the pre uparmored turtle back rigs had a lexan composite glass, not a true ballistic glass but the lexan was supposed to face to the inside the true up armred had a windshield that weighed in around 200 pounds
