53's on an LMTV
engele
Nagold / Germany
Hi,
any news about the 16" tires?`Someone mount them and they fit?
I will order tires..... But i´m not sure. In the back is no problem. But on the front to the fender?
coachgeo
3,362
North of Cincy OH
This is a steyr 12m18 with 16' Tires. ???The Position of the Front Axel is on the lmtv more to the Front/fender???
sorry can't put the link in. YouTube steyr 12m18 16.00 excap
1 Looks so nice with big Tire, like a Truck for men's
2 good Solution to down with the rpm.
Any news or pictures?
This is a fmtv i think with 14.00tires. But Thats only about 6.3% larger.
http://www.military-today.com/trucks/m1083_mtv.htm
https://www.youtube.com/watch?v=Xh8cFjm7npQ
Just to clarify, are you saying the Steyr front axle is mounted further forward than ones on an FMTV?
Floridianson
2,439
Interlachen Fl.
I had thought about 53's on my MTV but if it does not fit in the stock rack then I will stay with the 395's. I don't want to get caught without a spare. I am a believer that the tire size does not make the Johnson any bigger and 395's are still a good size tire.
coachgeo
3,362
North of Cincy OH
only reason I'd consider larger tires are to bridge the gap between pocket book, eventual need for new tires anyway and high speed (oxymoron) 3rd member. Another words; since will eventually NEED new tires... and will never really NEED high speed geared 3rd members... a taller tire just seems logical in between selection between NEED and WANT.
1951M1078
185
Glendale,AZ
Would you if the tire crane/holder could be made to fit the bigger tire ?
engele
Nagold / Germany
Hi,
i checked my lmtv today. The Most Problem ist the Mount for the cap Suspension. Even the 395 Tires rub on it. ��
I think to modifie the Tire rack should the easier Problem. On the rear tires are about 5cm Space to the Center and on the front about 3 cm when the axles is crossed, is the crossed the right Word? Hope so.
Best regards
Chism
Anchorage
No,
the LMTV axle is further forward.
If you look more closely, the fore-aft axle positions on each truck are actually nearly identical. The centerline of the hub on each truck is just aft of the front edge of the extended cab window.
The big difference is that the Steyr has a significantly greater ride height. The top of the rim is below the first solid stepping point on the 12m18, while the top of the rim on the LMTV is above the first stepping point. That's at least a 4-inch ride height difference. Not sure if this difference is due to frame, springs, blocks, and/or axles...thoughts?
TNriverjet
22
Nashville, TN
They "fit". However, wheel travel may bring the meaty monsters in contact with frame and bed structure. I would question if the front will hit during normal turning. All that said, I did see a truck being built by a FD for brush fires with them on it. Check out post #24 of this thread.
coachgeo
3,362
North of Cincy OH
On the 4x4 is there room to put say a one or two inch block lift under the leaf springs? For 6x6 or 4x4 one could put in cut a small wheel well into the bed? if needed. Not sure how one could lift the rear of a 6x6 to accommodate the 53's
TNriverjet
22
Nashville, TN
I believe the limitation on a 6x6 will be that the rear axles are too close together for 53's. The tires on the rear will contact each other or not even fit by my measurements. I can't imagine the fabrication/engineering needed to spread the axles apart. That would not be worth the trouble IMHO.
coachgeo
3,362
North of Cincy OH
Agreed, granted it matters one's experience. Very competent fabricator Welder might find it just a heavy duty project to tackle. Would expect if someone reallly wanted to and had the means; they would have to make longer leaf springs and everything else that attaches to leaf spring and/or the axle would have to be lengthened as well... Axles hang on each end of the leaf spring thus with them being further apart probably would mean the center attachment the inverted leaf spring pivots on would have to be beefed up and the list goes on... and on... and on.
rd3war
PA
I think a one or two inch lift would work ok under the leaf springs. Since a lot of these trucks are 20+ years and have very long leaf springs with only 3 in the stack it would not surprise me if gravity has caused them to sag slightly. So a one inch lift might actually get the ride height back to where it originally was. Factory shocks should still be ok with that small of a lift. Another thing would be to make sure that the air ride is functional for the cab, that would also add a couple inches of vertical clearance for larger tires.
TNriverjet
22
Nashville, TN
I may have just found information that will make my earlier post obsolete... Video of a M-1088 in operation with larger shoes...
https://www.youtube.com/watch?v=h8Egy5Wfit8
and...
https://www.youtube.com/watch?v=eD2PTA9w2DA
coachgeo
3,362
North of Cincy OH
Just checked and they responded to my questions to my surprise. Here is what they posted at youtube.
GorillaRig said:
coachgeo said:
is the spare also a 16x20? Does it raise and lower fine? Did you modify the Spare Tire holder to fit the larger tire? Have you used lower air pressures with the 16x20's. especially concerned for potential tire contact between two tires in rear. Looks like you put a different model tire as furthest back of the two on each side..... was this cause tire diameter of one is little smaller than other to help avoid potential contact? Any rubbing on chassis with front tires? Did you lift anything to allow for better fitment of these over-sized tires? THANK YOU in advance for providing this information.
REPLY:
The spare is not a 16x20, the spare rack would need modified to hold that size. Yes, it raises and lowers great. We have not used lower air pressures with the 16x20s. The different tires are the same sizes, just different treads, what we had in stock. The front tires only rub on chassis with hard turns. No, have not lifted anything on truck to fit tires better. ......
