- 3,871
- 504
- 83
- Gray Court SC
Make a loading dock at both places.
Don't even THINK about loading the tractor on ramps. I don't even like loading equipment on a LOWbed on ramps. If you can build an earthern "loading dock"on both properties.......Great........if not use a trailer. the slightest moisture/mud on the ramps can cause disaster. I can't count the times I've had a dozer slide off a lowbed in the winter here in Maine. I assure you it is NO fun.[/QUOTE]
Yes,,,,, It is a wild ride.... I can speak from experience.... I hate wood or steel beds in the winter time... even with caulks on my dozer grousers It can be a killer.
When it gets cold, those tractor tires won't have the "gription" on steel decking like they might when temperatures are warmer out....Don't even THINK about loading the tractor on ramps. I don't even like loading equipment on a LOWbed on ramps. If you can build an earthern "loading dock"on both properties.......Great........if not use a trailer. the slightest moisture/mud on the ramps can cause disaster. I can't count the times I've had a dozer slide off a lowbed in the winter here in Maine. I assure you it is NO fun.
