goat4hooves
- 3
- 3
- Idaho
I cannot get the frequency adjustments with in specs (58 Hz) on the low end called out in the TM. The cable has run out of length. The attached picture shows where sits the governor without the cable installed and the corresponding frequency is just below 60 Hz on the generator meter. The low end adjustment screw will not engage flat section of the governor speed lever. When the frequency adjust cable installed it goes as low as 62 Hz.
Is it possible for the governor speed lever to be clocked or positioned wrong on assembly?
