aftermarket Speedo
juanprado
3,180
Metairie/La (N'awlins)
Thinking of replacing my stock mechanical speedo since mine does 69/70. I know they have the electronic 80mph in the later models.
My thought was to use an aftermarket like this autometer #2690 since it mechanical and change the bulb to 24v . Anyone gone this route?
lindsey97
wynnewood, oklahoma
Looked up the specs on summit racing for the autometer 2690.
diameter of instrument: 3 3/8". Input is 5/8"-18 threaded adapter with .104" square drive.
I looked at a Stewart Warner speedometer I have out of a M939 5 ton, it measures 3 3/8" in diameter, has 5/8" thread input on the back, with a square drive tang.
I am curious what the input speed is of the 5 ton speedo and the autometer 2690. Could they both be 0-1000rpm like other class 8 trucks with mechanical speedometers?
juanprado
3,180
On the hmmwv I think it is all good, direct mechanical drive. Not sure on the M939, I know the A1 & A2 use a different 90* adapter on the cable due to the tire size to make the ratio correct but the speedo is the same unit. Should work ok as long as the correct tire size matches the ratio of the adapter, Speedo should display correct speed.
The autometer uses a plain 194 wedge bulb but those are out there in 24v led in many colors.
Action
1,564
East Tennessee
Speed is adjusted by a plastic gear inside the transfer case below the 90* elbow. I think I have seen 3 different gears. Only one bolt holds it in.
86humv
543
Texas
T/C gear is orange 35 teeth for 2.56 diff's, red 36 teeth for 2.73, and red and 40 or more teeth for 3.08's.
