wandering neurons
- 150
- 43
- Fallon, NV
Update on the wandering steering this afternoon:
1. Engine running, truck on all four tires on hard packed earth (parking spot for Goliath) - steering wheel would turn about 1.5-2.0 turns and stop turning. Tire would turn from straight ahead to maybe 10 degrees left turn. That's all. Had this happen once before when arriving home with Goliath. Maybe 1/8 turn of free play in wheel while testing this. But NOT FULL STEERING lock-to-lock.
2. Engine running, truck front axle on "trestles" (heavy duty jack stands), tires and wheels off the ground - steering worked normally, still about 1/8 of play, but full lock-to-lock left and right. While moving steering wheel and watching tire, the tire did not move smoothly, but was more like the second hand on a watch: small hesitation or notchiness between movements.
Additional notes:
Left front brake is hanging for certain. Right spins freely, off the ground, left will not spin. The rear shoe on the left side is contacting the drum.
Additionally, the left front brake shoes are installed with "Adjuster" down/forward, not up toward the air chamber/self adjuster. Sigh. Front wheel and tire is now off the truck. Will attempt to adjust the shoe, pull the drum, and use the -20-3 to do R&R of pads.
Also noticed something on the rear. After second test with engine running, I chocked the tires before shutting down the engine. I did not set the parking brake. Noticed noise from the left rear wheel well. Both left rear tire air brake chambers are making noise - one is doing a continual hiss, the other more of a steady popping noise at the same time the other is hissing. IIRC, these are not repairable items due to the parking brake springs inside.
Is is possible for them to be leaking as such?
More this weekend after I mess with the front brake. I'm not suspecting that of causing the wandering though, I'm still leaning towards a damaged steering box.
Additional notes:
