- 1,394
- 179
- 63
- Frisco Texas
I had to make a new hood hold open latch on the light bar over the fairlead. Pics when it’s 100% done.
If you mean my Little hay bale mover. Thats a Canadian M813 fitted with a Hiab the engineering units used these.Yes please. A crane on 53’s absolutely needs more discussion.
I have the same problem i had to cut some of the cross suport out after i ripped it off the bed. My plans is to use 6" channel and raise the bed.View attachment 706837
I had a guy tell me that he welded a piece a 1/4” plate on the bottom of his bed to keep from loosing chunks of his tires when it made contact like this. Sounds like a good idea. I guess a 12” wide piece of 1/4” flat maybe 16” long or so for each tire is cheap insurance if you like to go wheelin, or go missin trailers!
What kind of truck do you have. Post some pics of this crane truck with 53’s!I have the same problem i had to cut some of the cross suport out after i ripped it off the bed. My plans is to use 6" channel and raise the bed.
Sent from my LG-H812 using Tapatalk
Here are a couple more pics. Of my 813What kind of truck do you have. Post some pics of this crane truck with 53’s!
Turned 2-1/2 ton of scrap into #60 of new steel, and 12 ton of gravel today. $38 leftover for fuel...WIN!View attachment 707116View attachment 707117
