- 4,271
- 1,738
- Edmond, Oklahoma
Already have a new Delphi fuel pump on the way just in case.You can make a new fuel feed hose with 3/8" fuel hose and some split loom. It will be a bit longer but it will work fine. I made a few. I have done a few updates with a new metal line. A few look like the engine was pulled while the fuel line was still hooked up. Bent the metal line up and then kinked it. They just hammered it down. I removed the line and made a shorter metal line with a barbed/beaded edge fitting like the original one. If you want see pictures let me know. But I would remove the old line. Check it closely. Cut the ends of the hose off where the clamps were and reinstall with fresh clamps. Good Luck. But if the pumps wet. You may as well change that.
Filter was just changed when I installed new injectors. Their dry.
Good tip on that weird hose.
Will do that for sure.
Hopefully it’s just the fuel pump and my IP didn’t crap out.
Will troubleshoot when I get back.
HATE being gone and can’t work on it!!!!
