- 1,516
- 1,182
- TN
Oh ok, that's good : )New one has a heater and it plugs in the same. And I have a box of 500 extra heaters anyways.
Wow! You must move a lot of them.
I've modified the exhaust on my truck, and have moved the air dryer inside the frame rail, where the previous heat shield for the exhaust was.Hello!
Does someone tried to move the air dryer inside the frame? Need the place for a second fuel tank...
Or any other idea where put it?
Thanks a lot and regards from Italy?
Christian
I'll post pictures when I finish it.Hello Givinup!
That sounds great! I will check it, get my M1078 only in march/april, still in planing mode...
Thanks!
Christian
Yeah based on the look I can't imagine they are. There are some custom tank manufacturers here that can fabricate tanks and you give them the dimensions. I may go that route. If I do I'll share who I use, price, etcThank you! Yes they are great but not really cheap![]()
I love watching your truck build. Wish I had room for an extra toy to make a rock crawler.The install on my truck was straightforward: for some reason I did not experience the difficulties described by othersView attachment 825438
