wcuhillbilly
- 5
- 18
- Devils Tower, WY
AAAAHHHHH!!!!! Good ole Dayton Wheels..... Good Riddance
Nice Towbar sling action shot......
"Heavy Lifting" looks like your middle name.
Use caution in your modifications, beam frame buildings have outward thrust on the “legs” especially under snow load and require a foundation designed to account for this.Unloaded my "new to me" 40x60 I beam shop skeleton. No pole barn here,,, lucked out and found a surplus mine Butler I beam building that was dismantled years ago.. This means no center supports, with 38x58 open un restricted movement inside. Only problem is the walls are 12ft tall, thus Im gonna have to set it up on pillions to get it up to 16-18ft walls so I can get my taller equipment in the door.... but for what I paid... Im not hurting if some modifications need to be made.... (have welder will create,,,, and re- create).View attachment 708612
View attachment 708613View attachment 708614
Already taking this into consideration,. Know a few structural engineers,. Current plan is the concrete pillers embedded in the ground. Then extending the truss ends ( already pre-drilled for extensions) out about 12-14' as lean too additions which makes the original 8 points of ground contact "T" supports instead of"I" supports. The additional out rigging adds a total of 16 ground contact points instead of 8 and distributes load more equally.Use caution in your modifications, beam frame buildings have outward thrust on the “legs” especially under snow load and require a foundation designed to account for this.
Looking good!Put some new shoes on the old girl. 16.00r20 XZL on lmtv wheels.![]()
Sent from my SM-S820L using Tapatalk
Nice job on the winch.
Waynesville is near Maggie valley but both places are in Haywood county and there talking like 8-24 inches but the numbers keep changing so I’m not sure the exact amount and yeah I love my wrecker has made a lot of heavy jobs a whole lot easier.Yeah, you guys are getting/about to get some major snow! Good time for chains.
My parents have a summer home in Maggie Valley (Waynesboro?).
These big wreckers are amazing.
