I'd like to find a TM for HDT 90000 btu heater
Poccur
146
Roanoke, VA
The auction is for an SHC...Space Heater Convective...They are self powered...You have an onboard battery that you charge before deployment...when in the field the battery starts the fuel pump and the fan...once the flame is established the heat is blown into the space by the fan...On the way out of the heater the heat goes over a thermopile (like a bundle of thermo-couples), the power generated by the thermopile is routed back to charge battery..the circle is complete:)
Presto!! Self powered heater..
Poccur
146
Roanoke, VA
It is a 24VDC battery by the way in the larger BTU models...smaller ones have 2 x 12V batteries in them..
So?? Did you buy the SHC?? Enquiring minds need to now...
gimpyrobb
dumpsterlandingfromorbit!
27,791
786
Cincy Ohio
ZiggyO has some of these, might want to send him a PM. His wife is in the hospital, so have patience on a reply.
NEIOWA
128
NE IOWA
The link was to a like item they auctioned off. FD can get no cost from DOD surplus. But I'd like to find a TM to look over before I request transfer.
kloppk
4,176
Pepperell, Massachusetts
Scroll up to post #6
Click on "Poccur" in the very left side of the post
Click Private Message in the pop up box
Fill out the PM message with a title and text of your message to Poccur
Scroll down and click Submit Message
porkysplace
1,496
mid- michigan
Unless his PM box is full then it won't go through , but he does have a e-mail option when you follow the above directions.
