Halftrack axle nut sockets..............
1,125
So they WWII halftrack takes two different axle nuts, serviced by one 2-sized socket.
The front one, you can't use a modern civvy one because the axle stub sticks out too far. The socket bottoms out before you get onto the nut.
Is there a way around this? Do one of you have an original socket I can buy/borrow/rent?
And no, I'm not gonna' use a chisel.
It's FSN 41W 2612-25
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Why not make one? Bore out an old socket an weld it to another. I've done this multiple times and while somewhat ugly, works just fine.
1,125
What size is it and how deep does it need to be?
3 1/4" (I think, gotta' check again and I'm not at home) and probably 2" deeper than a standard axle nut socket
8683jb
Lakeside, CA
20180121_203414.jpgThe socket is 8-sided, 3-1/4" on one end, 3-7/8" on the other. I couldn't find an original or one deep enough either so I just bent up a strap, welded a nut to it and bolted it through the sides of the socket. I drilled the socket at both ends. If you do this you’ll need a carbide drill - these sockets are hard as heck. I just used a masonry bit in the drill press and it went right through. I used a 1/2" bit for 3/8" bolts so they'd be quick & easy to remove and replace to move the strap from one end to the other.
If you strike out on finding or making one, I may have mine back together in the next week or so, and if I do I can send you this tool to borrow.
Jon
