- 9,604
- 1,493
- mid- michigan
PCB=Power Control Box
Also you have not mentioned any of the tests from the troubleshooting section of the TM's that you have performed . Do you have a multi-meter they are a must for tracking electrical problems. As 74M35A2 stated rebuild or buy a new PCB this has to work before anything else will. We can sit here and guess all day every electrical problem is different and your going to have to do some testing and provide results for much help here . The PCB is designed to be a weak point to protect the rest of the electrical system.
Here are some related threads on the PCB . the help you get is only going to be as good as the information you provide , your the one who has to do the tests .
http://lmgtfy.com/?q=site+steelsoldiers.com+%3Bhow+to+rebuild+a+5+ton+pcb
