The easy path to the block drain is to disconnect the negative battery cable and roll the alternator out of the way.
![block-drain.jpg block-drain.jpg](https://www.steelsoldiers.com/data/attachments/449/449918-9a05259ae42708a8ea27fa8aa24bfe15.jpg)
That Rotella ELC stuff turns out to be RED. Says it's silicate and sulfate free diesel rated antifreeze so I went ahead and used it. Strange that it only reads good to zero on my hydrometer at 50%. That will be fine for around here but normal green stuff would go to -20* minimum at 50%. Easiest way I found to get it in was to siphon.
![20161217_163433.jpg 20161217_163433.jpg](https://www.steelsoldiers.com/data/attachments/449/449919-da7290e8871165752c0ea89b16f4fdc1.jpg)
Radiator design is a bit of a mystery. Never seen a cross flow radiator with both hoses on the same side tank. I suppose it must have a divider or baffle mid tank to direct the flow through the channels. That sideways cap opening is not the best design I've seen either.
