DatGuyC
- 22
- 18
- Essex, Maryland
I've got some projects I'm working on with my truck and figured people might not only be interested in the stuff I'm doing but could offer expertise I don't have. The main project right now is swapping in a cummins 12 valve from a 1995 ram 3500 and using the dodge 47rh transmission. This thread will kinda be a dumping ground of stuff I've done and what I plan on doing in the future. A place to put ideas out there and get feedback, good or bad. This is a side project and I'm in no rush so the progress will be slow but I hope to really get into it when it warms up outside. I usually have several different projects going on at the same time so it might get jumbled up but whatever, that's how I work. If you see anything you want more information on then feel free to ask, this is a learning thread for everyone.
So far completed:
Refreshed the cummins with lots of new parts
Rebuilt the 47rh to be stronger than stock
Swapped inputs on the np242 so it mates with the 47rhs 23 spline output shaft
2" body lift on the hmmwv
swapped the garbage stock brake switch for a more normal automotive one
reverse lights
Ibis tek light bar with more robust 1/8 steel brackets
front high-back seats
H1 trailer hitch
4 man divider
interior lights
24 bolt wheels/tires
A2 Airlift bumper
Rhino tire carrier
All new soft top kit
Halogen headlights with replaceable 100 watt bulbs, they are a lot better than the sealed beams
Rubber matt on the tunnel
other stuff that I dont remember haha
Current projects as of the beginning of this thread:
Rear blockout bar to cover the gap left by the 2" body lift
Adding rear AUX fuel tank
Electric speedometer swap
rear fender AC condensers
I've taken a lot of pictures over the years so as I find them I might make posts about that little project. For the first pictures I'm going to have a before and after just to see how far its come. The first picture is when it first got delivered off the rollback, the last one was taken this summer and is pretty much how it sits now.
So far completed:
reverse lights
H1 trailer hitch
4 man divider
interior lights
A2 Airlift bumper
Rhino tire carrier
