Tatertot51804
- 0
- 0
- Marietta Sc
I'm not complaining!Yeah, I told Tatertot the wind blew the G749 sickness from my place to his!![]()
Thanks! The paint seems to be doing pretty decent for going on with a brush. Just need to get more primer.What a fantastic job you are carrying out. That truck will look great any way you do it. Your Way!.
Unfortunately there's not much gas tank left. It's pretty much rotted away. Someone had put an external pump on it at one time. I need to take it apart and clean it to see if it's still good. Current plan is to get it running and try to get it in gear to make sure the Trans will move it. After that I'm going to put it on jack stands and pull all the wheels so I can drain all 3 axles, repack wheel bearings, replace hub seals and re do the brakes. Just saving that part for last until I know the rest is goodI would go through the fuel tank and parts. Pull the pump and filter screens. here is a link to help
with that: https://www.steelsoldiers.com/showthread.php?151013-Fuel-filter-screens-on-XM211
I would have the tank cleaned and replace the in tank pump with an exterior one as well as an
exterior in line filter. I think Alfa Heaven has the exterior pumps if they are still in business, but you can find other substitutes. There is a spot above the tank where you can mount one.
Go thru the drive train, splines, etc. I found water in the differential on mine. When replacing
wheel bearings there is a little detail that gets overlooked. You need to put a bit of cork in the keyway. There is instructions here on SS somewhere.
When replacing wheel cylinders, there are two per drum.
That's all I can remember for now. I'll add more when I remember. It's been awhile.
Good luck, these are great trucks.
Whoever parked the truck 30 or so years ago removed the water plug from the transmission and the drain from the radiator. It looks to me like the head gasket blew and they parked it with plans to fix it eventually and never go around to it. From what I can see the cooler looks nice and clean through the drain plug hole. The Trans oil looks brand new too but I'm still going to drain it and put new stuff in it because who knows what has settled to the bottom after all these yearsOn the bottom of the transmission pan there are two plugs, one labeled oil and the other water. Drain the coolant (water) and remove the front cover on the transmission pan. Carefully clean out any crud that might be in the compartment. A garden hose should work fine, just no high pressure washers. This is the heat exchanger for the transmission working with the same theory as the ones in the bottom tank of the radiator on cars and trucks. Keeping it clean allows the transmission to be properly warmed or cooled by engine coolant. If it is badly silted up it can cause the transmission to run too hot leading to failure.
I told myself I wasn't going to let this truck take a long time to do. Trying to get done what I can. Still have a long ways to go. I'm using behr exterior latex paint. Kind of wish I hadn't though. Too late to change. I got the paint code off of this site. The color looks good. It just doesn't like to get wet and it keeps raining on me.You are cleaning that truck up fast. Looks great!! What paint did you use and what is the paint code?
Very cool that you and SturmTyger380 live so close.
What are you using your apply it? Looks like it went on really well. I'm putting mine on with a brush and roller. It's dry to the touch but when it gets wet it changes colors. It gets really light. I'm painting mine in the driveway where it got dropped off when I bought it so unfortunately I can't keep it dry until it cures. The next 2 days will be the longest it's been wet since I painted it so I hope it doesn't mess it upI'm using Behr as well. So far I am very happy with it, but I have been careful to not get it wet until dry.
What is the paint doing since it keeps getting wet?
I was looking at that one. I think it would be hard for anything to cover up the brush marks at this point. One more gallon of paint should be enough for me to finish the truck.I am using this airless sprayer from Harbor Freight with a Graco 315 tip. It works really well. I have not had to thin the paint at all to spray.
https://www.harborfreight.com/airless-paint-sprayer-kit-60600.html
Your paint should be fine if it isn't bubbling up or anything. A few days in the hot spring/summer sun will cure the paint in no time.
