Looking for MEP-831A Schematics
AfghanVeteran2010
29
Odessa/Texas
Title pretty much sums it up, I'm looking for MEP-831A Schematics that I can actually see. I have looked in the TM 9-6115-639-13&P in back where schematics are. When I zoom in to get a closer look, I cant read it. I have tried Google it, it just pulls the TM up. I have also checked the TM section on this forum.
Any ideas where I can look?
Example of zoomed schematic
kloppk
4,201
Massachusetts
The schematic in the TM 13&P dated 15 August 2005 has real clear schematics. Get you hands on a copy of that version.
If you can't locate it just PM me your email address and I'll send you a copy of it.
Here is a zoom in on the 2005 version..
The newer 13&P dated 30 April 2010 has lousy, fuzzy schematics.
Here is a zoom in on the 2010 version..
Guyfang
27,251
Burgkunstadt, Germany
Why don't you simply put the 2005 extracted schematics into the TM forum? Had someone told me that the schmatics sucked, I would have taken care of that before.
Guyfang
27,251
I looked through the 2010 schematics, and found no changes from the 2005 schematic. How could I do that so fast? Well, the finger above, normally tells you when something has been changed in a schematic. It points to what ever has been changed. Simple way to see whats been changed.
For changed text in the manual, it looks like this. A thick dark vertical line, to the left or right of the text changed. I hope you can see this. Nothing seems to work right tonight.
View attachment Scan_0001.pdf
Guyfang
27,251
This is from TM section.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Did you go to TM upload section? Its one above the Generator TM forum. You have to use the upload section, and someone, a moderator, will review it and hopefully post it where it belongs. Try it.
