Last week I had to replace my R/F fender due to some trail damage
I decided to get a set of rock sliders, they came in and seem to be pretty sturdy with all hardware included
But being who I am , decide to order grade 8 bolts with washers an self locking nuts, and I chose the black bolts
The reason if to deter cross contamination from the aluminum & steel
The paint i used is a ceramic finish for the bolt heads and tread, once dried I also added Teflon tape to them
I did a dry run on the rock sliders, drilling all of the holes and bolting them into place
I then removed them to remove all of the aluminum shaving
Once the body was cleaned I applied a fresh coat of Carc 383 to the body and to the holes made to support the rock sliders
I also sprayed the inside of the rock sliders with an healthy coat of black Plasti Dip
I also used aluminum 2" flat stock to make 2" square washers to distribute the pull of the bolts when hitting something
And finally added some decals.
![IMG_1949.JPG IMG_1949.JPG](https://www.steelsoldiers.com/data/attachments/491/491991-7d292f05020412709926126cfb955273.jpg)
![IMG_2115.JPG IMG_2115.JPG](https://www.steelsoldiers.com/data/attachments/494/494834-e31101a9c79cf522ad51c75f62ef2ee2.jpg)
![IMG_2116.JPG IMG_2116.JPG](https://www.steelsoldiers.com/data/attachments/494/494835-1cf296cbc41f26ccc980543e249d5337.jpg)
![IMG_2119.JPG IMG_2119.JPG](https://www.steelsoldiers.com/data/attachments/494/494836-d93b4f8af208532b61edb2a809f5171b.jpg)
![IMG_2121.JPG IMG_2121.JPG](https://www.steelsoldiers.com/data/attachments/494/494837-9b185ad2eb468a14f3dfbff988ff141b.jpg)
