Yes.So will a 14.00×20 fit in the spare carrier?
with the fmtv m1088, you can get away with it, lmtv 4x4 I’m not too sure, I’ve been running mines with 1600’s for awhile with no liftI hope this thread didn't die.. Im still not sure if 53s will fit..![]()
which 1600 tire? Do you have high speed axles? Any performance results such as change in MPG, cruise speeds etc.? Turn issueswith the fmtv m1088, you can get away with it, lmtv 4x4 I’m not too sure, I’ve been running mines with 1600’s for awhile with no lift
That's interesting. We did not get resolution on the longer bolt tho. Will poke around some more, no hurry, I am allocating 2 years for the build as I am still working. That "job thing" takes up all my time.a fellow 53's on an LMTV planned to cut center out of a spare set of steel wheels and use that as a spacer for front axle. Easy way to solve some of the issues. Prior to doing that he did a good bit of trimming. Last I heard he's been happy with that and not done the spacers. Has a crap load of miles on the tires now and seems happy. .
https://www.pirate4x4.com/forum/expedition-vehicles/2635225-lmtv-m1078-79-camper-build-2.html
