NSN 2320013601898. And no, I do not know what the UOC is. I would love to learn more! Thanks for your help!
[FONT="]You did not give me all the info , but its enough.
NSN 2320-01-360-1898[/FONT]
[FONT="]
Look at the cover of your TM 9-2320-365-24P. Look for the NSN 2320-02-360-1898, in the middle of the page, down about half way. Next to it on the left is the model number for your truck.
TRK. CAR., M1078[/FONT]
[FONT="]
Below are the two types of M1078. W/WN, (With Winch) and W/O WN, (With Out Winch) is the first listed, and your NSN is listed to the right. That is your truck. Whenever you are looking for parts, you should know this info, as there are 7 different types of trucks listed in this manual. And the different trucks are very similar, but do have some differences. The way to tell what parts go to what truck is the trick. [/FONT]
[FONT="] Turn to page TM page 7, (PDF reader page 17) and look at[/FONT][FONT="] 5. Special Information. [/FONT][FONT="]Under this heading is an explanation for the UOC, Usable On Code.[/FONT]
[FONT="]USABLE ON CODE. The usable on code appears in the lower left corner of the Description column[/FONT]
[FONT="]heading. Usable on codes are shown as "UOC: . . . . . . ." in the description column (left justified) on the first[/FONT]
[FONT="]line applicable item description/ nomenclature. Uncoded items are applicable to all models. Identification of[/FONT]
[FONT="]UOC's used in this RPSTL, (Repair Parts Listing).
Under this explanation is listed your truck. [/FONT]
[FONT="]Trk, Car., LMTV M1078[/FONT]
[FONT="]LWB*
W/WN[/FONT]
[FONT="]LAB W/O WN[/FONT]
[FONT="]
Next to W/WB is an *. Below you see that the * means your truck has a PTO, (for the winch, something some of the other trucks do not have). Not important, until what parts for it. Now you know that your truck has a UOC of
LWB.
I looked at the brake system picture, and even though the parts may look different, the parts listed in that section fit ALL of the vehicles listed in this manual. Sometimes the pictures do not reflect the actual item in your hand, but are supposed the right part. [/FONT]
[FONT="] [/FONT]
[FONT="]But this is not always the case. Sometimes when you look at the picture of, say a brake system, there is for instance, one brake shoe in the picture. When you look at the item description, it has the same item listed several times. That’s because the different model trucks have different brake shoes.[/FONT]
[FONT="] [/FONT]
[FONT="] The below listing is just an example. I did not look through the whole book to find something special. This is from the rear light bracket mounting hardware. Just as an example. As you can see, Item number
4 is listed twice. On the picture its only there once, but for two different trucks, one kind of nut is used, and on another two different trucks, another kind of nut is used. [/FONT]
[FONT="] [/FONT]
[FONT="]4[/FONT][FONT="] PAOZZ 19207 12414308-019 NUT,SELF-LOCKING,EX M10 X 1.5...... 8[/FONT]
[FONT="]UOC:LWB,LAA,LAD[/FONT]
[FONT="] [/FONT]
[FONT="]4[/FONT][FONT="] PAOZZ 19207 12414308-025 NUT,SELF-LOCKING,EX................. 4[/FONT]
[FONT="]UOC:LAA,LAB[/FONT]
[FONT="] [/FONT]
[FONT="]Now you turn to page 204, (PDF reader page 55
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
and look for item number 9. Now look at page 204-1, Item number 9. See, its listed two times. Now you tell me what washer is used with your truck. This is an easy one.[/FONT]
[FONT="] [/FONT]
