I have joined the Goat herd
combat32
106
Booneville AR.
Well radiator is in and I'm bushed, I have developed quite a bit of respect for the wheel mechs that worked on these trucks, everything is stupid hard.
2 days work and it seems like I haven't made much progress but I actually have.
I should be on the road to McDonalds by Friday:naner:
m38inmaine
67
Maine USA
Looks good Tom, you can get the coolant with the "pink" cap at NAPA, I always try it with water first just in case.
combat32
106
Booneville AR.
Thanks for the advice, well screwed up again, mouted the radiator and shroud without the fan in, thinking i would slip it in last, no way jose, now i gotta take it back apart, I love this truck.
SgtMajHarper
585
Falcon, CO
I just absolutely love reading everyone else's posts about working on things and their useful pictures a few times before I venture out and cautiously consider doing anything to my trucks. For what it is worth......all of you guys have suffered and banged knuckles and cussed but not for in vain I assure you!!!
I have notes and lists of things to do and NOT to do all over the place based on those experiences you all made before me.
combat32
106
Booneville AR.
Glad i took mark in Maine's advice and filled up with water first, i had a regular old waterfall coming out the bottom of the truck.
Went under to get my bath and the drain plug at the bottom of the water pump housing was mia, had a brass plug that fit for now, i bet a petcock goes in there.
So far no other leaks!
m38inmaine
67
Maine USA
There is a petcock with a 3/16 line that runs about a foot along the oil pan that is the coolant drain line.
combat32
106
Booneville AR.
I used some fine swear words this week, thankfully no small children or nuns about:oops:
combat32
106
Booneville AR.
Making progress still, trying to get an hour or two in every day after work. Dash disassembled, I can save the speedo but will replace all the other gauges. Got my cut wiring harness all figured out now. Had to call m38inmaine for some advice and he came thru as usual.
Only 1000 things left,
combat32
106
Booneville AR.
More progress, some setbacks, but that is normal in a project like this , something which I am sure you are all familiar with.
Charlie 6, I hope to have mine looking as good as yours, looks like your truck was a fire truck in it's previous life as well.
Got the fuel system buttoned up, except for the tanks which I am working on now. Starter relay is installed, this truck never had one installed before.
And I found a replacement light for my stop light on the instrument panel, mine was totally fubar, so I am using one out of a heater control box, it is the same except for the color, maybe some red magic marker to make it red? I have found no other replacements.
Charlie 6
17
Claremore/Oklahoma OK
The brownish red is primer paint. My goat I believe came straight out of a national guard infantry brigade, according to the marking I found on it. I think Mississippi. It had 1980 camo paint scheme so I don’t believe local fire department or forest service touched it.
anyone can figure out the marking.52D8F166-F00E-4E7E-9DFC-4FF845C2D371.jpg34CCAD0F-26CF-46D8-8A01-8F3ACFBCDDF0.jpgB4013A44-CA1E-4892-A4D3-CDF91C5FC59E.jpg86929751-C582-4520-AC09-B0DBFB57AD71.jpgAAAC5CA9-26C7-4583-8422-1D819AA61CF2.jpg52D8F166-F00E-4E7E-9DFC-4FF845C2D371.jpg52D8F166-F00E-4E7E-9DFC-4FF845C2D371.jpgB4013A44-CA1E-4892-A4D3-CDF91C5FC59E.jpgBF0B8AA0-7110-42E8-B48F-BFD6923FE1FA.jpg
combat32
106
Booneville AR.
Looks like a nice truck, I see NG which I'm sure is National Guard and what looks like BDE which would be brigade, cant make out the rest.
