richingalveston
- 120
- 63
- galveston/Texas
still got my 6.2 available. lots of new parts. very cheap
Was hoping that it wasn't the IP, but thats what I figured was wrong.I replaced my ip last fall with a rebuilt unit , bleeding lines didnt take long at all. 4-5 10 seconds of cranking with a starter cool down in between and I was good. My guess is the IP has an issue, if you have fuel to ip and from ip but none to the injectors.
Hi Rsh4364I had DCP out of Memphis rebuild mine. $ 274.90 free shipping.
Yeah, Mark at Oregon Fuel Injection mentioned the Stanadyne additive too. I know I've read a little about it before from other people here on SS. Guess I need to find some too.I read the reviews and ratings and saw nothing negative relating to the 6.2 diesel, and went with them. Been 6-7 months still happy. I do run a little stanadyne lubricant with fill ups.
Hello Again Cucvrus!I have used Diesel Care out of Memphis for the past 20 years. No negative results. A few people bought CUCV's from me and are driving around in them with the Diesel Care pumps. No complaints that I heard of yet. And if you have to sue someone over a set of delivery nozzles you need a life. Really not much gain in that suit. Most parts are fine for the intended use. But many parts are used beyond the intended use and fail or under perform then people blame the parts. Most cases error on the user or installer. I watched a guy hammer ball joints in place with a sledge. They never seated properly and he said it was because they were made in China. I zipped it up and walked away. Same as U joints and hammers. I see the bolts fell out of the pump on your engine. I would proceed to remove the entire front and pan from that engine before I was confident to put it back together and on the road. 1 small piece can spell disaster for that engine. Gears do NOT like metal mashed between them. Good Luck. lets hope it holds up better this time. No short cuts.
Before you pull it, are you sure the fuel shut off selnoid is working? Put 12 volts to the terminal where the big pink wire connects and see if there is a clicking sound. If not its cheaper to replace it than the whole pump. Also make sure you are getting 12 volts from the pink wire.
I was just looking at an ebay ad of theirs and DCP yesterday evening.I have used Pensacola Diesel many times. Both for pumps, injectors and small parts. They have a rebuilt pump for $395. Their core charge is only $150. I have two of their pumps and a one set of their injectors. I'm very pleased with their work. Maybe they can save you some money.
