- 439
- 47
- 28
- Blythewood, SOUTH CAROLINA
I have been working on rebuilding a front axle on one of my trucks. The truck has needed more work than any other truck I've ever owned... I replaced the bearings, the spindle bushings, as well as the inner seal retainers with seals already installed. When bolting the spindles back on to the Axle, with the axle shaft installed it appeared as though the axle shaft was too long. Basically I used the studs to pull the spindle all the way flash to the knuckle. I'm not sure if there could be an issue with an axle shaft ring. I am also not certain if the axle would've possibly had a Bendix style axles and the style is a little different being the Spicer type now. The pictures are of the old seal retainers that I removed that obviously had too much pressure on them as well. It appears as though I have the same issue even replacing the parts that I did.
Any help would be appreciated thanks
