I've installed the Red Dot AC kit ([FONT="]RD-2-4233-OP)[/FONT] in my m998 recently and the air coming out of the vents is not as cold as I would expect.
4 lbs of freon was loaded after using the vacuum pump and ensuring no leaks as evident by watching the ac manifold gauge set. The coldest the AC I've recorded coming out of the vents is around 60 using a meat thermometer. I get around 48 degrees in my personal car.
Questions for all you experts:
1) My Condenser fans turn on when high pressure hits around 270 and cycle back off after running for about 6 seconds. When the fans are running the air seems colder. How often does your Condenser fans run (all the time, cycle on and off)?? I was thinking of running power to the condenser fans to a switch that I can keep the Condenser fans on all the time when it's super hot outside. Thoughts?
2) The instructions stated the new compressor has oil already supplied so I did not add any additional oil when adding freon. Even a mechanic I showed the install instructions seemed to think the compressor already had oil. Anyone else think differently?
Thanks in advance!
Thanks in advance!
